[Gdal-dev] Modify existing georeferencing (was: Fusion tool bug fix)
Mario Beauchamp starged at videotron.ca
Wed May 12 20:47:40 EDT 2004
Hi Frank,
On Mon, 10 May 2004 10:14:57 -0400, Frank Warmerdam <warmerdam at pobox.com> wrote:
>It is possible to modify existing georeferencing under some circumstances
>with SetGeoTransform().  However, it is driver dependent and you would need
>to have the file open with update access.  It *should* normally work with the
>GeoTIFF driver if the file is open for update access.
It indeed works. I have written a very simple script to do that from the command line:
http://pages.infinit.net/starged/gdal/setgeo.py
Thanks for clearing that up...
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
