[Gdal-dev] Re: Re: how to extract data from OGR
Jacob Bensabat jbensabat at ewre.com
Fri May 14 08:57:05 EDT 2004
Thanks a lot
It looks more complicated indeed but more complete.
jac
----- Original Message -----
Newsgroups: gmane.comp.gis.gdal.devel
Sent: Thursday, May 13, 2004 5:10 PM
Subject: Re: Re: how to extract data from OGR
> Jacob Bensabat wrote:
> > Hi and thanks a lot for your help
> > Indeed I work using C++ instead of C. Please indicate if there are major
> > issues that I should be aware
> > of (so I can start on the right foot), sample code using c++ would be
great.
> > Also could you show how I can querry for PENS, BRUSHES, patterns etc.
> > Sorry to bother, but while the lib. looks exciting, the learning curve
is
> > really steep.
> Jacob,
> I have placed the code used by MapServer to read OGR data on the web.
This
> includes support for reading the style information and using it.  However,
> this is *not* a simple example.  It is real live code with lots of
complexity
> not useful to you.
>    http://gdal.velocet.ca/~warmerda/mapogr.cpp.txt
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
