[Gdal-dev] Getting Data From OGR
Jacob Bensabat jbensabat at ewre.com
Sun May 16 02:59:43 EDT 2004
Hi
I have now a conceptual question. I went over the file you have posted and what I see is that you have defined other containers for
processing the data stored in the OGR layers.  What is the rationale for that ?
Would it be justified to use directly OGR ? If not what is the reason ?
thanks
jac.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040516/62bbdb89/attachment.html
