[Gdal-dev] RE: Re: WinCE port
Martin Daly Martin.Daly at cadcorp.com
Wed May 19 04:36:04 EDT 2004
Andrey,
> I have tried to use Embedded VC 4.0 with the libtiff library
> and found a big problem: how to deduce the compiler used to
> build the code? MSVC defines _MSC_VER constant which can be
> used to identify the compiler. Does something similar exist
> for the embedded edition, which can be used to distinguish it
> from other compilers and from the 'normal' MSVC? Or we should
> use manually defined flag in the configuration files?
You can use the _WIN32_WCE constant.
We have ported libtiff to Windows CE using eVC++ 3.0, and only had to
make changes in tif_win32.c and tiffcomp.h.  I can send these, and an
eVC++ 3 .vcp, if you would like them.
Regards,
Martin Daly,
Technical Director,
Cadcorp
