[Gdal-dev] RE: Re: WinCE port
Andrey Kiselev dron at ak4719.spb.edu
Wed May 19 05:45:07 EDT 2004
On Wed, May 19, 2004 at 09:36:04AM +0100, Martin Daly wrote:
> > I have tried to use Embedded VC 4.0 with the libtiff library
> > and found a big problem: how to deduce the compiler used to
> > build the code? MSVC defines _MSC_VER constant which can be
> > used to identify the compiler. Does something similar exist
> > for the embedded edition, which can be used to distinguish it
> > from other compilers and from the 'normal' MSVC? Or we should
> > use manually defined flag in the configuration files?
> You can use the _WIN32_WCE constant.
Ok, thanks for advice.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
