[Gdal-dev] SDTS - syntax for ogrinfo
Tyler Mitchell TMitchell at lignum.com
Tue May 25 16:43:58 EDT 2004
Right on - that worked, thanks.
gdal-dev-admin at remotesensing.org wrote on 05/25/2004 11:37:37 AM:
> Tyler Mitchell wrote:
> > I've got some SDTS data, apparently, including files like:
> > $ ls
> > MDBDABDF.DDF  MDBDCATD.DDF  MDBDDQCG.DDF  MDBDIDEN.DDF  MDBDPC01.DDF
> > MDBDABDM.DDF  MDBDCATS.DDF  MDBDDQHL.DDF  MDBDIREF.DDF  MDBDSPDM.DDF
> > MDBDAHDR.DDF  MDBDCATX.DDF  MDBDDQLC.DDF  MDBDLE01.DDF  MDBDSTAT.DDF
> > MDBDBFPC.DDF  MDBDDDSH.DDF  MDBDDQPA.DDF  MDBDNA01.DDF  MDBDXREF.DDF
> > MDBDBFPS.DDF  MDBDDQAA.DDF  MDBDFF01.DDF  MDBDNO01.DDF
> > but can't seem to get ogrinfo to do anything with them.  I've various
> > permutations and combinations of ogrinfo.  Can someone give me a hint?
> Tyler,
> You need to run ogrinfo against the CATD file.
> eg
> ogrinfo -ro MDBDCATD.DDF
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
