[Gdal-dev] build gdal with grass support error
Wed May 26 09:34:25 EDT 2004
Richard Greenwood wrote:
> I have a problem building GDAL with GRASS support under Linux.
> First I built and installed libgrass (from www.remotesensing.org)
> Next I try to build GDAL --with-grass=/usr/local/lib/ but it fails with
> the following error messages:
> make[2]: Entering directory `/usr/local/src/gdal/gdal_cvs/frmts/grass'
> /bin/sh ../../libtool --mode=compile g++ -Wall  -O2  -I/usr/local/lib/
> -I/usr/local/lib//include   -I../../port -I../../gcore -I../../ogr
> -I../../port -c -o ../o/grassdataset.o grassdataset.cpp
>  g++ -Wall -O2 -I/usr/local/lib/ -I/usr/local/lib//include -I../../port
> -I../../gcore -I../../ogr -I../../port -c grassdataset.cpp  -fPIC -DPIC
> -o ../o/.libs/grassdataset.o
> grassdataset.cpp: In static member function `static GDALDataset*
>    GRASSDataset::Open(GDALOpenInfo*)':
> grassdataset.cpp:513: error: invalid conversion from `int (*)(...)' to
> `int   (*)()'
> Any idea what I am doing wrong?
Rich,
Not your fault.  There is a bug about this:
   http://bugzilla.remotesensing.org/show_bug.cgi?id=408
Just hand edit your code changing this:
   typedef int (*GrassErrorHandler)();
to this:
    typedef int (*GrassErrorHandler)(...);
or the other way around as needed.
I am vaguely hopeful that the code in CVS works properly.
Best regards,
