[Gdal-dev] build gdal with grass support error
Richard Greenwood rich at greenwoodmap.com
Fri May 28 05:12:40 EDT 2004
> Frank Warmerdam wrote:
>> Not your fault.  There is a bug about this:
>>   http://bugzilla.remotesensing.org/show_bug.cgi?id=408
>> Just hand edit your code changing this:
>>   typedef int (*GrassErrorHandler)();
>> to this:
>>    typedef int (*GrassErrorHandler)(...);
>> or the other way around as needed.
>> I am vaguely hopeful that the code in CVS works properly.
>> Best regards,
> Thanks Frank and Alessandro for the prompt replies. Changing
> (*GrassErrorHandler)(...) to (*GrassErrorHandler)() solved the problem.
> I had updated from CVS last night, so unfortunately I guess it's not
> fixed in CVS.
I may have mislead you about the CVS in the sentence above - my local
copy of GDAL source was pointed at the 1.9 CVS branch. (I'm not to swift
with CVS). The 1.2.0b source tarball compiled with grass support correctly.
Apologies if I caused any confusion.
Richard Greenwood
www.greenwoodmap.com
