[Gdal-dev] Using ogr2ogr -f PostgreSQL on Windows works now
Emil Zegers EZS at DeStraat.NL
Fri May 28 12:26:41 EDT 2004
Hello Frank,
Thanks for your reply (and sorry for mailing to the wrong list :-)
I've changed the syntax to:
ogr2ogr -f "PostgreSQL" PG:"user=ezs dbname=myGISdb host=localhost password=geheim port=5432" D:\klusjes\LVE\R2058\data\basis\shp\nl_gemeente.shp overwrite=yes
And now it works, thanks.
(Had to use 'overwrite=yes' because relation was already created I think)
Best regards,
Emil Zegers
Emil Zegers wrote:
> Hello,
> i'm trying to use ogr2ogr together with the Win32 PostgreSQL 7.5/PostGIS snapshot from Mark Cave-Ayland (http://www.webbased.co.uk/mca/pgsql75win.zip)
> But at the moment  end up at this error:
> ERROR 1: PGconnectcb failed.
> could not create socket: Address family not supported (0x0000273F/10047)
> The syntax I use is:
> ogr2ogr -f "PostgreSQL" PG:user=ezs PG:dbname=myGISdb PG:host=localhost PG:password=geheim PG:port=5432 D:\klusjes\LVE\R2058\data\basis\shp\nl_gemeente.shp
> Something seems to go wrong with connecting to the host.
Emil,
This is a quoting issue.  The whole dataset name needs to be a single
argument to ogr2ogr, so you have to quote it.
eg.
ogr2ogr -f PostgreSQL "PG:user=ezs PG:dbname=myGISdb PG:host=localhost PG:password=geheim PG:port=5432" \
I presume that because the PG:port=5432 was missing from the dataset name it
was unable to even connect to the database properly.
I would add that this is more of a GDAL/OGR issue than an OpenEV one, and might
be better discussed on that list.
Best regards,
______________________________________________________
 This message has been checked for all known viruses
