[Gdal-dev] AIGReadBlock failure to read some ArcInfo Grid tiles
Fri May 28 15:04:23 EDT 2004
Olsen, Keith wrote:
> Hello,
> I am new to GDAL so forgive me if this issue has already been addressed.
> I am using the GDAL AIG driver to read arcInfo grids with values that
> range from 0-5.6 million.  When I read one of these grids I get the
> following warning from gridlib.c:
> *Warning 1: Unsupported Arc/Info Binary Grid tile of type 0x20 encountered.*
> *This and subsequent unsupported tile types set to no data value.*
> The read does not crash my program, but it skips 10-20% of the 4x256
> pixel tiles in my image.  The non-skipped tiles seem to be read
> correctly.  When I clip out a smaller area with a dropped tile, I get
> the same problem.  The grids can be read in arcInfo and arcMap with no
> problems.
Keith,
Support for block type 0x20 (32bit integer) was added March 26th.  You will
need a more recent build of GDAL, such as from a nightly CVS snapshot.
Best regards,
