[Gdal-dev] RE: DTED Level 2
Martin Daly Martin.Daly at cadcorp.com
Thu Nov 4 10:13:27 EST 2004
> Martin Daly wrote:
> > Frank,
> > One of our users is having performance problems with DTED
> Level 2 via
> > GDAL.
> ... Martin goes on to mention that OpenEV can load DTED Level
> 2 files fairly quickly, but in freestanding use of GDAL read
> performance is terrible for DTED Level 2.
> Martin,
> OpenEV does not (normally) use the dted.dll.  It is part of
> OGDI but is essentially just cruft. In fact OpenEV
> The problem you are encountering is that your GDAL raster
> cache is smaller than the size of the DTED level 2 file.  The
> DTED file is read by column and is cached in columns.  When a
> scanline is read by an application each of the columns needs
> to be read in but is kept in the cache.  However, if the
> cache isn't large enough to hold all the blocks (the entire
> DTED file) then by the time the last column is being read,
> the first column will be expired from the cache. That means
> that every scanline read means re-reading all the profiles.
> Essentially this is a cache thrashing situation.
> OpenEV has a different default GDAL cache size which is why
> it is fairly fast.
> So, my suggestion is that you review the GDAL cache size you
> set from your application.  The default in GDAL is 10MB but I
> think a DTED level 2 file is roughly 25MB.  You can verify
> that this caching is the issue by calling
> GDALSetCacheMax() to set the max to 30MB or so.
> One step that you might want to take would be to check the
> block size of any file you open, and ensure that the GDAL
> cache size is forced at least large enough to hold enough
> blocks to satisfy one complete scanline request.
> The danger of setting the GDAL cache too high is that it will
> tend to soak up alot of memory when accessing large files.
> But the danger of having the cache too small is terrible
> cache thrashing in some cases.  The worse case is profile
> oriented files like DTED.  But there can also be problems
> with large files that have big tiles or that are all in one tile.
That worked a treat.
> I have taken the liberty of cc:ing my response to gdal-dev
> since I think the answer is of broad interest.  I hope you don't mind.
You didn't, but I don't, so I did.
Thanks,
Martin
