[Gdal-dev] ENVI and raster attributes/color support
Vincent Schut schut at sarvision.com
Thu Nov 11 03:28:27 EST 2004
Frank Warmerdam wrote:
> Vincent Schut wrote:
>> Dear Frank, Markus, others,
>> would it be possible to implement GetCategoryNames() support for a
>> grass57rasterband? I think it might be relatively easy, as grass
>> already supports this using G_read_cats function (see
>> http://mpa.itc.it/markus/grass50progman/node136.html), but I'm not
>> very good in C...
>> Though there's limited client support for this feature, I hope to be
>> able to use it from my own Python scripts.
> Vincent,
> Looking at the Categories structure, it seems that you need to pass the
> pixel
> values through some scaling mechanism in order to get an index into the
> list
> of category labels.  There is also a bunch of stuff about a Quant_table
> that
> looks like each category may actually have ranges.
You're right, it is more complicated than I thought. Indeed in grass a
category can belong to a range of values, too. Thanks for looking into
this, anyway.
Vincent.
> The simplistic approach to categories in GDAL is based on the assumption
> that
> the list of categories is indexed into by integer pixel values without any
> further transformation.
> Therefore, I am not sure that it makes sense to directly map category names
> from GRASS to GDAL since it would break down in any case where a pixel
> value
> transformation needs to be applied to compute the category index.
> Also, does this relate to the color rules that Radim scans with
> G_get_f_color_rule() to build the metadata color table?
> Best regards,
