[Gdal-dev] CreatCopy Bug? GDAL 1.2.3
Thu Nov 11 11:25:31 EST 2004
Jason Hughes wrote:
> Hi I've used CreateCopy on a GeoTiff's and Nitf's that are directly South-up
> its GeoReferencing isn't copied correctly.  It actually flips the geo
> referencing but not the image.   I'm not sure if this bug carries over to
> GDAL 1.2.4 as there are no binaries available yet.
Jason,
Could you submit a bug report including a smallish input file that can be
used to demonstrate the problem?  This should not be the case.  I would add
that it is unlikely to have changed in 1.2.4.
Best regard,
