[Gdal-dev] --with-grass
Maciek Sieczka werchowyna at pf.pl
Sun Nov 14 10:33:41 EST 2004
I tried to build gdal against --with-grass to enble the r.out.gdal for the
first time.
1. built Gdal (CVS 2004_11_13) --without-grass
2. built Grass (CVS 2004_11_06) --with-gdal
3. make distclean in the Gdal dir, built --with-grass like following:
    ./configure --with-hdf4 --without-ogdi --with-grass=/urs/local/grass55
and got:
    checking for G_asprintf in -lgrass_gis... no
    configure: error: --with-grass=/urs/local/grass55 requested, but
    libraries not found!
Can somebody help me to sort it out?
BTW: why does "make uninstall" invoked in the source dir after the
"./configure, make, make install" doesn't work? Should I give more detailed
