[Gdal-dev] linking error with gdal 1.2.4 dll
Chad Berkley berkley at nceas.ucsb.edu
Tue Nov 16 12:06:19 EST 2004
Great!  That worked.  Thanks a lot.
chad
Chapman, Martin wrote:
> Chad,
> You need to link to gdal_i.lib.  Then place the gdal12.dll some where in
> your path or in the same directory as your exe.  Let me know if that was
> the problem.
> Martin
> -----Original Message-----
> From: Chad Berkley [mailto:berkley at nceas.ucsb.edu]
> Sent: Monday, November 15, 2004 6:59 PM
> To: gdal-dev at xserve.flids.com
> Subject: [Gdal-dev] linking error with gdal 1.2.4 dll
> Hello,
> I'm trying to link code against the gdal12.dll file that is built with
> nmake.  I am getting a linking error from MSVC++6.0 that says:
> c:\GDALBuild\bin\gdal12.dll: fatal error LNK1136: invalid or corrupt
> file.  Error executing link.exe.
> I have tried building the dll cleanly several times and I can't figure
> out why VC++6.0 (nmake) builds the dll without error but then won't
> allow me to link against it.  I have tried this with 1.2.4 and 1.2.3
> with the same result.  Has anyone seen this error or know how to fix it?
> Thanks in advance for any help.
> Chad Berkley
> National Center for Ecological Analysis and Synthesis
> berkley at nceas.ucsb.edu _______________________________________________
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
