[Gdal-dev] Problem compiling under VS.NET
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Thu Nov 18 10:06:57 EST 2004
Tried that. I've recently "upgraded" from VS6 to VS.NET and this might be
the first time I've tried to recompile gdal using the new compiler.
It looks like I don't have a full installation of the compiler. The old
iostream libraries and headers (iostream.h, fstream.h, strstream.h, etc.)
don't exist anywhere in my computer. The new, ANSI Standard headers (without
the .h extension) are in the Vc7/include directory. But, of course, it's not
as easy as simply removing the ".h" from the #include line. The compiler
then complains about:
   C++ exception handler used, but unwind semantics are not enabled. Specify
/EHsc
Any other ideas?
Thom
Thom DeCarlo
If you love sausage or government, you should never
witness the creation of either.     -Goethe
> -----Original Message-----
> From: Chapman, Martin
> Sent: Wednesday, November 17, 2004 7:37 PM
> To: Thom DeCarlo; GDAL developers
> Subject: RE: [Gdal-dev] Problem compiling under VS.NET
> Download the zip file for windows, unzip to c:\gdal, and change the
> GDAL_HOME in the nmake.opt to c:\gdal.  Then run the compiler as
> specified in the build instructions for windows on the gdal site.  Let
> me know if that works.
> Martin
> From: Thom DeCarlo
> Sent: Wednesday, November 17, 2004 2:20 PM
> To: 'GDAL developers'
> Subject: [Gdal-dev] Problem compiling under VS.NET
> Hi all,
> I downloaded last night's tarball and found that I cannot compile using
> VS.NET'03. The crash occurs in frmts/gtiff
> C:\SVS_DE~1\GDAL-C~2\frmts>cd gtiff   && nmake /NOLOGO /f makefile.vc
>     cd ..
>   cl /nologo /Ox /MD -I..\..\port -I..\..\ogr -I..\..\gcore -Ilibtiff
>     -Ilibgeotiff /c geotiff.cpp
> geotiff.cpp
> libtiff\tiffio.h(498) : fatal error C1083: Cannot open include file:
>     'iostream.h': No such file or directory
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> I think the problem is iostream.h is now called iostream (with no
> extension). There are many other similar changes. Can someone tell me
> how to get this to compile with VS.NET?
> Thanks,
> Thom
