[Gdal-dev] prj string problem
Gao, Peng pgao at esri.com
Thu Nov 18 11:00:01 EST 2004
I have a tiff image and gdalinfo returns the following prj string:
PROJCS["unnamed",
    GEOGCS["NAD83",
        DATUM["North_American_Datum_1983",
            SPHEROID["GRS 1980",6378137,298.2572221010002,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6269"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4269"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","26986"]]
ESRI ArcGIS software does not accept the prj string. One reason could be
the PROJECTION parameter is missing from the PROJCS definition. According
to the WKT spec at
http://geoapi.sourceforge.net/snapshot/javadoc/org/opengis/referencing/doc-
files/WKT.html,
PROJECTION is not optional within a PROJCS. How should I fix this?
Thanks,
Gao, Peng
