[Gdal-dev] Building from CVS
Markus Neteler neteler at itc.it
Mon Nov 22 12:03:45 EST 2004
Hi Tyler,
I had the same problem, but a simple
  make clean
  make
was sufficient.
Markus
On Sun, Nov 21, 2004 at 09:25:16PM -0800, Tyler Mitchell wrote:
> I decided to start with a fresh checkout of the source and it compiled okay
> this time.  Is there some other flag I should be using during an update?  Or
> have things just changed so much that it gets bungled?
> Tyler
> On November 21, 2004 08:53 pm, Tyler Mitchell wrote:
> > Hi folks,
> > Just building from CVS (did an update -d) and can't get through the
> > compile. Here's what I'm hitting.
> > ../.libs/libgdal.so: undefined reference to `GDALWarpSrcAlphaMasker'
> > collect2: ld returned 1 exit status
> > make[1]: *** [ogrinfo] Error 1
> > make[1]: Leaving directory `/home/tyler/src/gis/gdal/ogr'
> > make: *** [ogr-apps] Error 2
> > I'm guessing it's close to the end.  Any pointers?
> > Tyler
> > Gdal-dev mailing list
> > Gdal-dev at xserve.flids.com
> > http://xserve.flids.com/mailman/listinfo/gdal-dev
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
