[Gdal-dev] OGR API Tutorial
Chapman, Martin MChapman at sanz.com
Mon Nov 22 19:33:30 EST 2004
Frank,
My only comment to your docs is that I would add is the use of
ExecuteSQL().  The reason I say this is because the management of a
OGRLayer depends on how you create it.  In other words, if you use
ExecuteSQL you must call ReleaseResultSet() to get rid of it.  Other
than that I think it is awesome that you are taking time to update the
user docs.  I also wonder if you should include some links to some
select user group postings that have good code snippets in them.
Good job,
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, November 22, 2004 7:43 AM
To: gdal-dev
Subject: [Gdal-dev] OGR API Tutorial
Folks,
I have a decent tutorial for reading and writing data with the GDAL API.
However, I have not had a corresponding tutorial for OGR.  Finally, I
have written one.  It is available at:
   http://gdal.org/ogr/ogr_apitut.html
If anyone sees any particular problems with it let me know.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
