[Gdal-dev] OGR API Tutorial
Mon Nov 22 22:24:37 EST 2004
Chapman, Martin wrote:
> Frank,
> My only comment to your docs is that I would add is the use of
> ExecuteSQL().  The reason I say this is because the management of a
> OGRLayer depends on how you create it.  In other words, if you use
> ExecuteSQL you must call ReleaseResultSet() to get rid of it.  Other
> than that I think it is awesome that you are taking time to update the
> user docs.  I also wonder if you should include some links to some
> select user group postings that have good code snippets in them.
Martin,
The ExecuteSQL() idea is good.  If I get a chance, I'll take a look at that.
I'm not so keen on trying to link to individual mailing list messages.  Those
sort of links tend to be fragile and require maintenance regularly.
Best regards,
