[Gdal-dev] Re: GDALWarp - NO_DATA Replace?
Tue Nov 23 00:42:03 EST 2004
Jason Hughes wrote:
> Frank - To use pfnPreWarpChunkProcessor do I have to set dfWarpMemoryLimit
> in order to know what the chunk size is to process the chunk myself?  Or is
> there another way to get the chunk size without setting it?
Jason,
The WarpKernel::nSrcXSize and nSrcYSize are the size of the chunk you are
given.  You do not need to try and figure it out from the dfWarpMemoryLimit.
Best regards,
