[Gdal-dev] problem with gdal 1.2.5?
Norman Barker normanb at comsine.co.uk
Tue Nov 23 13:24:06 EST 2004
I have GDAL 1.2.3 running on my Windows machine and this works fine
(from the spot/chicago geotiff samples on ftp.remotesensing.org)
gdalwarp -t_srs wgs84 UTM2GTIF.TIF out.tif
however on linux running GDAL 1.2.5 with Proj and the NAD27 add in I get
the following
ERROR 1: geocentric transformation missing z or ellps
ERROR 1: GDALWarperOperation::ComputeSourceWindow() failed because
the pfnTransformer failed.
Can anyone see anything wrong?
Thanks,
Norman
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
