[Gdal-dev] problem with gdal 1.2.5?
    Norman Barker
    normanb at comsine.co.uk
    Tue Nov 23 13:57:46 EST 2004
Hi Frank,
I have recompiled Proj 4.4.9 and added your fix but get the same error.
I am using the GDAL 1.2.3 that comes with OpenEV on windows and
that works fine.  Do you have any other suggestions?
Thanks,
Norman
Frank Warmerdam wrote:
> Norman Barker wrote:
>> Hi,
>> I have GDAL 1.2.3 running on my Windows machine and this works fine
>> (from the spot/chicago geotiff samples on ftp.remotesensing.org)
>> gdalwarp -t_srs wgs84 UTM2GTIF.TIF out.tif
>> however on linux running GDAL 1.2.5 with Proj and the NAD27 add in I get
>> the following
>> ERROR 1: geocentric transformation missing z or ellps
>> ERROR 1: GDALWarperOperation::ComputeSourceWindow() failed because
>> the pfnTransformer failed.
>> Can anyone see anything wrong?
> Norman,
> This is a known problem with the release version of PROJ.4, and
> attempting
> to transform multiple points, some of which fail.  I have attached the
> fixed pj_transform.c.  I *think* that will fix the problem.  I don't know
> why this would have changed between GDAL 1.2.3 and 1.2.5.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> * $Id: pj_transform.c,v 1.14 2004/11/05 06:05:11 fwarmerdam Exp $
> * Project:  PROJ.4
> * Purpose:  Perform overall coordinate system to coordinate system
> *           transformations (pj_transform() function) including reprojection
> *           and datum shifting.
> * Author:   Frank Warmerdam, warmerdam at pobox.com
> * Copyright (c) 2000, Frank Warmerdam
> * Permission is hereby granted, free of charge, to any person obtaining a
> * copy of this software and associated documentation files (the "Software"),
> * to deal in the Software without restriction, including without limitation
> * the rights to use, copy, modify, merge, publish, distribute, sublicense,
> * and/or sell copies of the Software, and to permit persons to whom the
> * Software is furnished to do so, subject to the following conditions:
> * The above copyright notice and this permission notice shall be included
> * in all copies or substantial portions of the Software.
> * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
> * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
> * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
> * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
> * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
> * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
> * DEALINGS IN THE SOFTWARE.
> * $Log: pj_transform.c,v $
> * Revision 1.14  2004/11/05 06:05:11  fwarmerdam
> * Fixed pj_geocentric_to_geodetic() to not try and process HUGE_VAL values
> * (those that have failed some previous transform step).  Related to bug:5B
> *     http://bugzilla.remotesensing.org/show_bug.cgi?id=642
> * Revision 1.13  2004/10/25 15:34:36  fwarmerdam
> * make names of geodetic funcs from geotrans unique
> * Revision 1.12  2004/05/03 19:45:23  warmerda
> * Altered so that raw ellpses are treated as a essentially having a
> * +towgs84=0,0,0 specification so ellpisoid shifts are applied.
> * Fixed so that prime meridian shifts are applied if the coordinate system is
> * not lat/long (ie. if it is projected).  This fixes:
> * http://bugzilla.remotesensing.org/show_bug.cgi?id=510
> * Revision 1.11  2004/01/24 09:37:19  warmerda
> * pj_transform() will no longer return an error code if any of the points are
> * transformable.  In this case the application is expected to check for
> * HUGE_VAL to identify failed points.
> * As part of the implementation, I added a list of pj_errno values that
> * are transient (ie per-point) rather than indicating global failure for the
> * coordinate system definition.  We use this in deciding which pj_fwd and
> * pj_inv error codes are really fatal and should be reported.
> * Revision 1.10  2003/08/21 02:09:06  warmerda
> * added a bunch of HUGE_VAL checking
> * Revision 1.9  2003/03/26 16:52:30  warmerda
> * added check that an inverse transformation func exists
> * Revision 1.8  2002/12/14 20:35:43  warmerda
> * implement units support for geocentric coordinates
> * Revision 1.7  2002/12/14 20:14:35  warmerda
> * added geocentric support
> * Revision 1.6  2002/12/09 16:01:02  warmerda
> * added prime meridian support
> * Revision 1.5  2002/12/01 19:25:26  warmerda
> * applied fix for 7 param shift in pj_geocentric_from_wgs84, see bug 194
> * Revision 1.4  2002/02/15 14:30:36  warmerda
> * provide default Z array if none passed in in pj_datum_transform()
> * Revision 1.3  2001/04/04 21:13:21  warmerda
> * do arcsecond/radian and ppm datum parm transformation in pj_set_datum()
> * Revision 1.2  2001/04/04 16:08:08  warmerda
> * rewrote 7 param datum shift to match EPSG:9606, now works with example
> * Revision 1.1  2000/07/06 23:32:27  warmerda
> * New
>#include <projects.h>
>#include <string.h>
>#include <math.h>
>#include "geocent.h"
>PJ_CVSID("$Id: pj_transform.c,v 1.14 2004/11/05 06:05:11 fwarmerdam Exp $");
>#ifndef SRS_WGS84_SEMIMAJOR
>#define SRS_WGS84_SEMIMAJOR 6378137.0
>#endif
>#ifndef SRS_WGS84_ESQUARED
>#define SRS_WGS84_ESQUARED 0.006694379990
>#endif
>#define Dx_BF (defn->datum_params[0])
>#define Dy_BF (defn->datum_params[1])
>#define Dz_BF (defn->datum_params[2])
>#define Rx_BF (defn->datum_params[3])
>#define Ry_BF (defn->datum_params[4])
>#define Rz_BF (defn->datum_params[5])
>#define M_BF  (defn->datum_params[6])
>** This table is intended to indicate for any given error code in
>** the range 0 to -44, whether that error will occur for all locations (ie.
>** it is a problem with the coordinate system as a whole) in which case the
>** value would be 0, or if the problem is with the point being transformed
>** in which case the value is 1.
>** At some point we might want to move this array in with the error message
>** list or something, but while experimenting with it this should be fine.
>static int transient_error[45] = {
>    /*             0  1  2  3  4  5  6  7  8  9   */
>    /* 0 to 9 */   0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
>    /* 10 to 19 */ 0, 0, 0, 0, 1, 1, 0, 1, 1, 1,
>    /* 20 to 29 */ 1, 0, 0, 0, 0, 0, 0, 1, 0, 0,
>    /* 30 to 39 */ 0, 0, 0, 0, 0, 0, 0, 0, 1, 0,
>    /* 40 to 44 */ 0, 0, 0, 0, 0 };
>/*                            pj_transform()                            */
>/*      Currently this function doesn't recognise if two projections    */
>/*      are identical (to short circuit reprojection) because it is     */
>/*      difficult to compare PJ structures (since there are some        */
>/*      projection specific components).                                */
>int pj_transform( PJ *srcdefn, PJ *dstdefn, long point_count, int point_offset,
>                  double *x, double *y, double *z )
>    long      i;
>    int       need_datum_shift;
>    pj_errno = 0;
>    if( point_offset == 0 )
>        point_offset = 1;
>/*      Transform geocentric source coordinates to lat/long.            */
>    if( srcdefn->is_geocent )
>        if( z == NULL )
>            pj_errno = PJD_ERR_GEOCENTRIC;
>            return PJD_ERR_GEOCENTRIC;
>        if( srcdefn->to_meter != 1.0 )
>            for( i = 0; i < point_count; i++ )
>                x[point_offset*i] *= srcdefn->to_meter;
>                y[point_offset*i] *= srcdefn->to_meter;
>        if( pj_geocentric_to_geodetic( srcdefn->a, srcdefn->es,
>                                       point_count, point_offset,
>                                       x, y, z ) != 0)
>            return pj_errno;
>/*      Transform source points to lat/long, if they aren't             */
>/*      already.                                                        */
>    else if( !srcdefn->is_latlong )
>        if( srcdefn->inv == NULL )
>            pj_errno = -17; /* this isn't correct, we need a no inverse err */
>            if( getenv( "PROJ_DEBUG" ) != NULL )
>                fprintf( stderr,
>                       "pj_transform(): source projection not invertable\n" );
>            return pj_errno;
>            XY         projected_loc;
>            LP	       geodetic_loc;
>            projected_loc.u = x[point_offset*i];
>            projected_loc.v = y[point_offset*i];
>            if( projected_loc.u == HUGE_VAL )
>                continue;
>            geodetic_loc = pj_inv( projected_loc, srcdefn );
>            if( pj_errno != 0 )
>                if( pj_errno > 0 || pj_errno < -44 || point_count == 1
>                    || transient_error[-pj_errno] == 0 )
>                    return pj_errno;
>                else
>                    geodetic_loc.u = HUGE_VAL;
>                    geodetic_loc.v = HUGE_VAL;
>            x[point_offset*i] = geodetic_loc.u;
>            y[point_offset*i] = geodetic_loc.v;
>/*      But if they are already lat long, adjust for the prime          */
>/*      meridian if there is one in effect.                             */
>    if( srcdefn->from_greenwich != 0.0 )
>            if( x[point_offset*i] != HUGE_VAL )
>                x[point_offset*i] += srcdefn->from_greenwich;
>/*      Convert datums if needed, and possible.                         */
>    if( pj_datum_transform( srcdefn, dstdefn, point_count, point_offset,
>                            x, y, z ) != 0 )
>        return pj_errno;
>/*      But if they are staying lat long, adjust for the prime          */
>    if( dstdefn->from_greenwich != 0.0 )
>                x[point_offset*i] -= dstdefn->from_greenwich;
>/*      Transform destination latlong to geocentric if required.        */
>    if( dstdefn->is_geocent )
>        if( z == NULL )
>        pj_geodetic_to_geocentric( dstdefn->a, dstdefn->es,
>                                   point_count, point_offset, x, y, z );
>        if( dstdefn->fr_meter != 1.0 )
>                    x[point_offset*i] *= dstdefn->fr_meter;
>                    y[point_offset*i] *= dstdefn->fr_meter;
>/*      Transform destination points to projection coordinates, if      */
>/*      desired.                                                        */
>    else if( !dstdefn->is_latlong )
>            XY         projected_loc;
>            LP	       geodetic_loc;
>            geodetic_loc.u = x[point_offset*i];
>            geodetic_loc.v = y[point_offset*i];
>            if( geodetic_loc.u == HUGE_VAL )
>                continue;
>            projected_loc = pj_fwd( geodetic_loc, dstdefn );
>            if( pj_errno != 0 )
>                    return pj_errno;
>                else
>                    projected_loc.u = HUGE_VAL;
>                    projected_loc.v = HUGE_VAL;
>            x[point_offset*i] = projected_loc.u;
>            y[point_offset*i] = projected_loc.v;
>    return 0;
>/*                     pj_geodetic_to_geocentric()                      */
>int pj_geodetic_to_geocentric( double a, double es,
>    double b;
>    int    i;
>    if( es == 0.0 )
>        b = a;
>    else
>        b = a * sqrt(1-es);
>    if( pj_Set_Geocentric_Parameters( a, b ) != 0 )
>        return pj_errno;
>        long io = i * point_offset;
>        if( x[io] == HUGE_VAL  )
>            continue;
>        if( pj_Convert_Geodetic_To_Geocentric( y[io], x[io], z[io],
>                                               x+io, y+io, z+io ) != 0 )
>    return 0;
>int pj_geocentric_to_geodetic( double a, double es,
>    double b;
>    int    i;
>    if( es == 0.0 )
>        b = a;
>    else
>        b = a * sqrt(1-es);
>        return pj_errno;
>            continue;
>        pj_Convert_Geocentric_To_Geodetic( x[io], y[io], z[io],
>                                        y+io, x+io, z+io );
>    return 0;
>/*                         pj_compare_datums()                          */
>/*      Returns TRUE if the two datums are identical, otherwise         */
>/*      FALSE.                                                          */
>int pj_compare_datums( PJ *srcdefn, PJ *dstdefn )
>    if( srcdefn->datum_type != dstdefn->datum_type )
>        return 0;
>    else if( srcdefn->a != dstdefn->a
>             || ABS(srcdefn->es - dstdefn->es) > 0.000000000050 )
>        /* the tolerence for es is to ensure that GRS80 and WGS84 are
>           considered identical */
>        return 0;
>    else if( srcdefn->datum_type == PJD_3PARAM )
>        return (srcdefn->datum_params[0] == dstdefn->datum_params[0]
>                && srcdefn->datum_params[1] == dstdefn->datum_params[1]
>                && srcdefn->datum_params[2] == dstdefn->datum_params[2]);
>    else if( srcdefn->datum_type == PJD_7PARAM )
>                && srcdefn->datum_params[3] == dstdefn->datum_params[3]
>                && srcdefn->datum_params[4] == dstdefn->datum_params[4]
>                && srcdefn->datum_params[5] == dstdefn->datum_params[5]
>                && srcdefn->datum_params[6] == dstdefn->datum_params[6]);
>    else if( srcdefn->datum_type == PJD_GRIDSHIFT )
>        return strcmp( pj_param(srcdefn->params,"snadgrids").s,
>                       pj_param(dstdefn->params,"snadgrids").s ) == 0;
>    else
>        return 1;
>/*                       pj_geocentic_to_wgs84()                        */
>int pj_geocentric_to_wgs84( PJ *defn,
>    int       i;
>    pj_errno = 0;
>    if( defn->datum_type == PJD_3PARAM )
>                continue;
>            x[io] = x[io] + defn->datum_params[0];
>            y[io] = y[io] + defn->datum_params[1];
>            z[io] = z[io] + defn->datum_params[2];
>    else if( defn->datum_type == PJD_7PARAM )
>            double x_out, y_out, z_out;
>                continue;
>            x_out = M_BF*(       x[io] - Rz_BF*y[io] + Ry_BF*z[io]) + Dx_BF;
>            y_out = M_BF*( Rz_BF*x[io] +       y[io] - Rx_BF*z[io]) + Dy_BF;
>            z_out = M_BF*(-Ry_BF*x[io] + Rx_BF*y[io] +       z[io]) + Dz_BF;
>            x[io] = x_out;
>            y[io] = y_out;
>            z[io] = z_out;
>    return 0;
>/*                      pj_geocentic_from_wgs84()                       */
>int pj_geocentric_from_wgs84( PJ *defn,
>    int       i;
>    pj_errno = 0;
>                continue;
>            x[io] = x[io] - defn->datum_params[0];
>            y[io] = y[io] - defn->datum_params[1];
>            z[io] = z[io] - defn->datum_params[2];
>            double x_tmp, y_tmp, z_tmp;
>                continue;
>            x_tmp = (x[io] - Dx_BF) / M_BF;
>            y_tmp = (y[io] - Dy_BF) / M_BF;
>            z_tmp = (z[io] - Dz_BF) / M_BF;
>            x[io] =        x_tmp + Rz_BF*y_tmp - Ry_BF*z_tmp;
>            y[io] = -Rz_BF*x_tmp +       y_tmp + Rx_BF*z_tmp;
>            z[io] =  Ry_BF*x_tmp - Rx_BF*y_tmp +       z_tmp;
>    return 0;
>/*                         pj_datum_transform()                         */
>int pj_datum_transform( PJ *srcdefn, PJ *dstdefn,
>    double      src_a, src_es, dst_a, dst_es;
>    int         z_is_temp = FALSE;
>    pj_errno = 0;
>/*      Short cut if the datums are identical.                          */
>    if( pj_compare_datums( srcdefn, dstdefn ) )
>        return 0;
>    src_a = srcdefn->a;
>    src_es = srcdefn->es;
>    dst_a = dstdefn->a;
>    dst_es = dstdefn->es;
>/*      Create a temporary Z array if one is not provided.              */
>    if( z == NULL )
>        int	bytes = sizeof(double) * point_count * point_offset;
>        z = (double *) pj_malloc(bytes);
>        memset( z, 0, bytes );
>        z_is_temp = TRUE;
>#define CHECK_RETURN {if( pj_errno != 0 ) { if( z_is_temp ) pj_dalloc(z); return pj_errno; }}
>/*	If this datum requires grid shifts, then apply it to geodetic   */
>/*      coordinates.                                                    */
>        pj_apply_gridshift( pj_param(srcdefn->params,"snadgrids").s, 0,
>        CHECK_RETURN;
>        src_a = SRS_WGS84_SEMIMAJOR;
>        src_es = 0.006694379990;
>    if( dstdefn->datum_type == PJD_GRIDSHIFT )
>        dst_a = SRS_WGS84_SEMIMAJOR;
>        dst_es = 0.006694379990;
>/*      Do we need to go through geocentric coordinates?                */
>    if( src_es != dst_es || src_a != dst_a
>        || dstdefn->datum_type == PJD_3PARAM
>        || dstdefn->datum_type == PJD_7PARAM)
>/*      Convert to geocentric coordinates.                              */
>        pj_geodetic_to_geocentric( src_a, src_es,
>        CHECK_RETURN;
>/*      Convert between datums.                                         */
>            pj_geocentric_to_wgs84( srcdefn, point_count, point_offset,x,y,z);
>            CHECK_RETURN;
>        if( dstdefn->datum_type == PJD_3PARAM
>            || dstdefn->datum_type == PJD_7PARAM )
>            pj_geocentric_from_wgs84( dstdefn, point_count,point_offset,x,y,z);
>            CHECK_RETURN;
>/*      Convert back to geodetic coordinates.                           */
>        pj_geocentric_to_geodetic( dst_a, dst_es,
>        CHECK_RETURN;
>/*      Apply grid shift to destination if required.                    */
>        pj_apply_gridshift( pj_param(dstdefn->params,"snadgrids").s, 1,
>        CHECK_RETURN;
>    if( z_is_temp )
>        pj_dalloc( z );
>    return 0;
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
