[Gdal-dev] Creating gdal package problem
MZM marazm at navigator.lv
Sat Nov 27 06:37:28 EST 2004
I'm just a newbee in Linux and I wanted to install GDAL clean way.
(Sorry for my eng.)
I culdn't understand how to create gdal package for Slackware. I
always install soft only from packages. Normal way of package
creation:
./configure --prefix=/usr
make
make install DESTDIR=/home/user/pkg/
or make install prefix=/home/install/pkg/usr
Then directory content are packed into package and only then
installed to /usr.
Problem is - GDAL ignores DESTDIR or PREFIX.
Same is on Gentoo - there pakage first is compiled (sugested to
compile with --prefix=/usr --mandir=/usr/share/man and
--infodir=/usr/share/info) and then installed to sandbox
(/var/tmp/package_name/image) and, only if there are no errors, then
it is moved to /usr. If during make install it tries to do something
in /usr, then installation is terminated.
I worked around python with --with-pymoddir, and all seemd fine,
except:
libtool: install: warning: relinking `_gdalmodule.la'
(cd /var/tmp/portage/gdal-1.2.5/work/gdal-1.2.5/pymod; /bin/sh ../libtool
--mode=relink g++ gdal_wrap.lo numpydataset.lo
gdalnumeric.lo ../libgdal.la -o _gdalmodule.la
-rpath /var/tmp/portage/gdal-1.2.5/image//usr/lib/python2.3/site-packages
-no-undefined -avoid-version -module )
g++ -shared
-nostdlib /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crti.o /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtbeginS.o  .libs/gdal_wrap.o .libs/numpydataset.o .libs/gdalnumeric.o
-L/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4 -L/usr/X11R6/lib
-L/usr/lib/lib
-L/usr/lib/gcc-lib/i686-pc-linux-gnu/../../../i686-pc-linux-gnu/lib-L/usr/i686-pc-linux-gnu/lib
-L/usr/i686-pc-linux-gnu/bin -L/usr/lib -lgdal
-L/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../../i686-pc-linux-gnu/lib
-L/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../.. -lstdc++ -lm -lc
-lgcc_s /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/crtendS.o /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../crtn.o
-Wl,-soname -Wl,_gdalmodule.so -o .libs/_gdalmodule.so
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/../../../../i686-pc-linux-gnu/bin/ld:
cannot find -lgdal
collect2: ld returned 1 exit status
libtool: install: error: relink `_gdalmodule.la' with the above
command before installing it
make[1]: *** [install] Error 1
make[1]: Leaving directory
`/var/tmp/portage/gdal-1.2.5/work/gdal-1.2.5/pymod'
make: *** [install-actions] Error 2
As can see form error - it looks in /usr/lib for some stuff (I'm not
a coder), buth that stuff isn't there - its in
some /tempinstalldir/lib.
So - where is my mistake? Is there way how to install gdal to some
tempdir before moving to /usr? I know about
--prefix=/tempinstalldir/usr, but it's ugly hack.
Any help welcome :)
TNX,
MZM.
Bezmaksas e-pasta adreses piedāvā http://webmail.delfi.lv/
