[Gdal-dev] TIFF with JPEG compression on Win32
Norman Vine nhv at cape.com
Fri Oct 1 09:57:03 EDT 2004
Julien Demaria writes:
> I don't know why but my gdal Win32 build doesn't support read or write TIFF
> with JPEG compression, but my Linux and Solaris builds work well :
> read error:
> Input file size is 2044, 1704
> 0.ERROR 1: JPEGLib:JPEG parameter struct mismatch: library thinks size is
> 464, caller expects 432
> Assertion failed: sp->cinfo.comm.is_decompressor, file tif_jpeg.c, line 606
> write error:
> 376, caller expects 360
> ERROR 1: JPEGLib:Improper call to JPEG library in state 0
> ERROR 1: TIFFWriteScanline failed.
> I compile my Win32 build with VC6 with netCDF, MrSID 4 and Kakadu support
> and with /Ox /MD /EHsc flags and /NODEFAULTLIB:LIBC linker flag.
> I've tested with the OpenEV_FW 1.8.2 package and it works well...
> If anyone has ideas of the causes, or similar problem....
You are compiling against two different jpeg installations
see thread starting here
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0304/msg00023.html
HTH
Norman
