[Gdal-dev] problem/bug about GDAL
Andrey Kiselev dron at ak4719.spb.edu
Sat Oct 2 05:16:02 EDT 2004
On Tue, Sep 28, 2004 at 10:23:14AM +0800, wjimage at sohu.com wrote:
> I have developed a FFT program based on GDAL,when read the geo.
> infomation using GetProjectionRef,it's ok, then i write it to the
> result file,the function return CE_None(read the geo. infomation
> immediatelly to another char * variable, it's ok,except that UTM is
> known as unnamed (why?,ERDAS img format)),but in the ERDAS system, the
> geo. information is NULL. In fact ,the geo. information is NULL when i
> use the output file of previous result as the input file. That means,
> the geo. information can't be written(i have tried GTiff and HFA)!
> Another bug: the input file and the output file is upside-down when
> using HFA format!
It is possible that the projection record in your ERDAS files did not
recognized properly by the GDAL. Could you upload the sample file
somewhere?
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
