[Gdal-dev] how to know if GDALOpen(filename,GA_Update) is valid ?
Tue Oct 5 09:02:15 EDT 2004
Julien Demaria wrote:
> I understand that each driver as special meta-datas GDAL_DCAP_CREATE and
> GDAL_DCAP_CREATECOPY if it support them ? and if a driver as a Create
> method, it must support the GA_Update mode, isn't it ?
Julien,
For the most part formats with a Create() method also support update but there
are a number off formats that support imagery update that do no have
Create() methods.
Best regards,
