[Gdal-dev] Problem compiling with kakadu
Chris Hodgson chodgson at refractions.net
Tue Oct 5 14:59:21 EDT 2004
Thanks, yah, it was the "--without-libtool" that I was missing.
Chris
Alessandro Amici wrote:
>Chris,
>On Monday 04 October 2004 23:42, Chris Hodgson wrote:
>>I'm working with gdal 1.2.1 and kakadu 4.2.
>>I tried only copying "libkdu_v42R.so" but that didn't work so I added
>>the symlink and that seemed to get my compile process a bit further at
>>least... I'm guessing my problem is somewhere in here...
>>When I try to compile gdal and I get the following at the end of the
>>make output:
>i don't have the possibility to test the kakadu driver directly, but to the
>best of my knowledge you need to (at least) do:
> $ ./configure ... --with-kakadu=$KAKADU_SOURCE_DIR --without-libtool
>where the $KAKADU_SOURCE_DIR is the source directory with the object files.
>cheers,
>alessandro
