[Gdal-dev] problem compiling GDAL1.2.3 with Xerces2.5.0
Norbert Thieme norbert.thieme at ilmenau.baw.de
Wed Oct 13 09:01:23 EDT 2004
Hello,
I have a problem compiling gdal 1.2.3 with xerces 2.5.0 on Linux. I
tried --with-xerces and got:
"configure: error: Please correct Xerces options, or don't enable Xerces."
The default Paths should be fine. For example the xerces include path:
"-I/usr/local/include/xercesc"
Some time ago I compiled gdal 1.2.0b with xerces 2.5.0 and it worked. Is
there a problem with the version of xerces? Which version will be better?
Any help will be appreciated.
Thanks in advance,
Norbert
