[Gdal-dev] gdalinfo
Dobmeyer, Todd tdobmeye at ball.com
Thu Oct 14 08:58:07 EDT 2004
Did you create your own tfw file or find one? I do not seem to have any
tfw files with my tif files. This is why I cannot find the information I
want? Thanks again!
Todd
-----Original Message-----
From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
Sent: Wednesday, October 13, 2004 12:42 PM
To: Dobmeyer, Todd; gdal-dev at xserve.flids.com
Subject: RE: [Gdal-dev] gdalinfo
Does the image come with a tfw? Your output suggests there's no
projection associated with your tif.
Here's what my gdalinfo looks like on GeoTiff's I create:
Driver: GTiff/GeoTIFF
Size is 1039, 3628
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235629972,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree (supplier to define
representation)",0.01745329251994328],
    AUTHORITY["EPSG","4326"]]
Origin = (-105.220222,40.261786)
Pixel Size = (0.00020000,-0.00020000)
Corner Coordinates:
Upper Left  (-105.2202222,  40.2617861) (105d13'12.80"W, 40d15'42.43"N)
Lower Left  (-105.2202222,  39.5361861) (105d13'12.80"W, 39d32'10.27"N)
Upper Right (-105.0124222,  40.2617861) (105d 0'44.72"W, 40d15'42.43"N)
Lower Right (-105.0124222,  39.5361861) (105d 0'44.72"W, 39d32'10.27"N)
Center      (-105.1163222,  39.8989861) (105d 6'58.76"W, 39d53'56.35"N)
Band 1 Block=1039x7 Type=Byte, ColorInterp=Red
Band 2 Block=1039x7 Type=Byte, ColorInterp=Green
Band 3 Block=1039x7 Type=Byte, ColorInterp=Blue
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041014/0f04c6b6/attachment.html
