[Gdal-dev] pct2rgb.py
Thu Oct 14 14:25:04 EDT 2004
Dobmeyer, Todd wrote:
> I honestly do not remember how I built gdal, if I did it with python
> support or not. I might rebuild this to make sure that I do add python
> support. I am on Windows XP Pro and am very new to gdal yet. To make
> sure I get python support, I should go out and find one of the OpenEV_FW
> builds? Or what exactly should I do? Thanks for your continued help and
> I am glad I chose to work with gdal!
Todd,
If you don't need to build everything yourself, I would suggest just
using the OpenEV_FW release for this task.
   http://gdal.org/dl/openev/OpenEV_FW_182.zip
It includes everything built nicely together, including the Python numeric
package which would be needed for gdal_merge.py to work (as noted by another
user).  On Windows when building GDAL you need to explitely set the PYDIR
in nmake.opt to get python support working.  I think there are some additional
complications related to the numeric support.  This is within your ability to
handle, but unless you need to build things yourself for some reason I would
suggest you avoid it.
Best regards,
