[Gdal-dev] OGR spatial indexes in Oracle
GIRAUD Pierre bluecarto at free.fr
Fri Oct 15 08:21:05 EDT 2004
  Hello,
I'm having to use an Oracle Spatial data base containing many feature
within Mapserver. And I'm in front of performance issues while spatial
indexes don't seem to work.
Trying to identify the problem at its source, I wrote those following
queries :
----->in sqlplus :
SQL> SELECT count(*) FROM ref_batiment a WHERE sdo_filter(a.geometry,
mdsys.sdo_geometry(2003,NULL,NULL, mdsys.sdo_elem_info_array(1,1003,3),
mdsys.sdo_ordinate_array(58750573,13847995,58751000,13900000)),
'querytype=window') = 'TRUE';
  COUNT(*)
         8
----> with ogrinfo :
aneto:~$ ogrinfo OCI:scott/tiger at aneto/orcl -sql "select a.geometry from
ref_batiment a" -spat 58750573 13847995 58751000 13900000
INFO: Open of `OCI:pierre/xbe9a51h at aneto.oco/orcl'
using driver `OCI' successful.
Layer name: select a.geometry, a.genre from ref_batiment a
Geometry: Unknown (any)
Feature Count: 97587
The time to get the info is obviously not the same.
What is the way I missed to get it working ?
Thx
Regards.
Pierre GIRAUD
camptocamp.com
