[Gdal-dev] Coordinate transform problem
Chapman, Martin MChapman at sanz.com
Tue Oct 19 11:55:40 EDT 2004
Ethan and Frank,
Thanks very much for your help.  After some debugging I think it is the
environment I'm using rather than anything related to GDAL/GEOS...which
is kind of what I figured since both of those libraries usually compile
without problems.
Thanks again,
Martin
	-----Original Message-----
	From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
	Sent: Tuesday, October 19, 2004 7:45 AM
	To: Frank Warmerdam; Chapman, Martin
	Cc: gdal-dev at remotesensing.org
	Subject: RE: [Gdal-dev] Coordinate transform problem
	Keep in mind if you install GEOS 2.x you'll need to upgrade to
postgis 0.9.0 or keep two versions of GEOS installed.
	-e
  _____
	From: gdal-dev-bounces at xserve.flids.com on behalf of Frank
Warmerdam
	Sent: Mon 10/18/2004 6:22 PM
	To: Chapman, Martin
	Subject: Re: [Gdal-dev] Coordinate transform problem
	Chapman, Martin wrote:
	> New question:  I installed gdal 1.2.3 on windows and it
compiled with no
	> problem.  Now I'm installing on Linux and I'm getting the
following
	> compiler error listed below.  Basically it can't find the geos
libs (I
	> think).  I already have geos loaded on my linux box with
	> PostGIS/Postgres and I'm wondering if that could be causing
the problem
	> (older geos version).  Question is...do I also need to load
geos
	> seperately from gdal in 1.2.3, or is that part of the gdal
source now?
	Martin,
	GDAL requires GEOS 2.0 or newer if you want GEOS support.  The
GEOS source
	is not part of GDAL so you need to pre-build and install GEOS if
you
	want to configure GDAL with it.   I don't know if PostGIS is
using
	GEOS 2.0 yet or not. I haven't actually tried to GEOS enable my
	installation yet.
	Best regards,
	I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
	light and sound - activate the windows |
http://pobox.com/~warmerdam
	and watch the world go round - Rush    | Geospatial Programmer
for Rent
	Gdal-dev mailing list
	Gdal-dev at xserve.flids.com
	http://xserve.flids.com/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041019/989f604b/attachment.html
