[Gdal-dev] gdalwarp, using GCPs with pixel positions outside the input image
Chris Campbell chris at alchemedia.jp
Thu Oct 21 08:07:04 EDT 2004
Hi
I am generating very large images which I rectify with gdalwarp, using
lat-lon GCPs. Because of the size of the input images, it is much more
practical to generate them in smaller sections, but I want each one of these
smaller images to go through the same transformation as it it's
corresponding part of the larger image would. Since the only pixel values
for the GCPs I have are relative to the large image, and I want to use all
available GCPs, I tried warping the smaller images by adding an offset to
the pixel value depending on where the smaller image is within the large
image..... of course this gives me some pixel values outside the image to be
warped.
For example say my large image would be 50,000x50,000 pixels with GCPs
spread fairly evenly through it. I generate a 2000x2000 section of it that
covers the area say from (bottomleft-topright) 6000,6000 - 8000,8000. Now I
warp this using GCPs which have their pixel values shifted by -6000,-6000.
The GCPs that had pixel values less than 6000 will now be negative, and GCPs
that had pixel values above 8000 likewise will not actually be in the image
to be warped..... hope this all makes sense!
Anyway, this method runs fine and without errors etc, but the small
rectified file is just not _quite_ the same as it's corresponding section in
the large file. It is very close, but seems to have different coefficients
for the warping calcluation.
So my question is, does using GCPs with pixel positions outside the image to
be warped screw up the transformation?
Thanks for any comments....
Chris
