[Gdal-dev] OGR: TIGER/Line polygons
Thu Oct 28 01:10:11 EDT 2004
Curt Mills wrote:
>     Filled polygons
>     Filled polygons w/holes
>     Hole polygons
> I handle the first two cases just fine, but something tells me that
> I missed a step somewhere and shouldn't be finding that third type.
Curt,
I'm not sure how you can identify something as a "hole polygon".  For instance,
it is not possible to create an OGRPolygon with a hole but no outer ring since
it always treats the first ring as the outer ring.
Best regards,
