[Gdal-dev] No python support for x86_64 with kakadu?
Chris Hodgson chodgson at refractions.net
Thu Oct 28 14:46:53 EDT 2004
I have compiled gdal successfully with kakadu on my machine, which is an
Athlon 64 FX. However, I didn't get python support for some reason.so,
going back to try to add it, I try this:
[root at dragonfly gdal]# python setup.py build
['pymod/gdal_wrap.c', 'pymod/numpydataset.cpp', 'pymod/gdalnumeric.cpp']
running build
running build_py
running build_ext
building '_gdalmodule' extension
c++ -pthread -shared build/temp.linux-x86_64-2.3/pymod/gdal_wrap.o
build/temp.linux-x86_64-2.3/pymod/numpydataset.o
build/temp.linux-x86_64-2.3/pymod/gdalnumeric.o -L./.libs -lgdal -o
build/lib.linux-x86_64-2.3/_gdalmodule.so
/usr/bin/ld: /usr/local/lib/libgdal.a(jp2.o): relocation R_X86_64_32 can
not be used when making a shared object; recompile with -fPIC
/usr/local/lib/libgdal.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
error: command 'c++' failed with exit status 1
hmm... something isn't kosher with the 64-bit relocation. I did compile
kakadu with -fPIC.
Here I see what is probably part of the problem:
[root at dragonfly gdal]# ./configure
--with-kakadu=/usr/local/src/v4_2_1-00488N --without-geos
--without-libtool --with-python --with-pic
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports
shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
appending configuration tag "F77" to libtool
checking for ranlib... (cached) ranlib
/usr/bin/ld: conftest2.o: relocation R_X86_64_32 can not be used when
conftest2.o: could not read symbols: Bad value
checking for g++ -shared ... no(1)
checking for ld -shared ... no
checking for dlopen in -ldl... yes
checking for main in -lm... yes
It does seem to find the fPIC option, but something else in conftest.o
fails... do I need to run autoconf myself to generate 64-bit compatible
configure tests? How can I do this? Is this likely to be part of my problem?
How can I tell if my existing libgdal.a was compiled with -fPIC? Or does
that even make any sense... I don't have a libgdal.so, because configure
doesn't think I have support for gcc -shared... something's icky here...
Help! Please!
Thanks,
Chris
