[Gdal-dev] OGR: how to get information about font name in style string for point features
ksa nil5-ksa at yandex.ru
Fri Sep 3 07:25:02 EDT 2004
----- Original Message -----
To: "ksa" <nil5-ksa at yandex.ru>
Cc: "gdal-dev" <gdal-dev at remotesensing.org>
Sent: Thursday, September 02, 2004 6:07 PM
Subject: Re: [Gdal-dev] OGR: how to get information about font name in style
> ksa wrote:
> > Hi,
> > I'm using ogr1.2.1 on Linux Slackware 9.1. I've got some difficulties in
> > getting
> > style of point features.
> > I have follow MIF file:
> > --top of MIF file
> > Version 300
> > Charset "WindowsCyrillic"
> > Delimiter ","
> > CoordSys Earth Projection 1, 0
> > Columns 2
> >   ID Integer
> >   Code Char(8)
> > Data
> > Point 36.145654 54.531409
> >     Symbol (45,0,10,"MapInfo Weather",0,0)
> > --end of MIF file
> > So, I have follow style string (by calling
OGRFeature::getStyleString()):
> > SYMBOL(a:0,c:#000000,s:10pt,id:"mapinfo-sym-45.ogr-sym-8").
> > There is no information about font name in that style string. How I can
get
> > information about font name? MIF-file contains the information about
font
> > name ("MapInfo Weather").
> > How I can get information about font name?
> Sergey,
> It appears the font information is lost even though it should properly be
> carried into the style string.  I would encourage you to file a bug report
> against GDAL's mapinfo driver about this, including an attached mid/mif
file
> set that demonstrates the problem.
> The bad news is that we are someone backlogged on mapinfo related issues
and
> it is unlikely to be resolved for a while.  The Mapinfo driver is fairly
> complicated and it takes some serious effort to get into the right
"headspace"
> to make fixes to the style related stuff.   I don't forsee Daniel or I
doing
> that in the near future and the original author of the .mid/mif section is
> no longer involved.
> If your need is sufficiently compelling, you could fund a bit of time to
> fix this particular issue or look into preparing a patch yourself (though
> this is a complicated area).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Hi, Frank.
It is really important for me to receive this information somehow. Can you
prompt me in what classes it's really necessary to make changes to receive
this information?
Thankful in advance.
