[Gdal-dev] gdal
Maciek Sieczka werchowyna at pf.pl
Fri Sep 10 04:33:14 EDT 2004
> On Wed, 2004-09-08 at 18:47, Maciek Sieczka wrote:
> > hello
> > can somebody tell me if it is safe now to build gdal (cvs) --with-grass?
> > I read some about it but I'm confused
> > I want to make the r.out.gdal in Grass work
> Maciek,
> It has worked fine for me. But I don't think it's what you need here.
> gdal --with-grass allows gdal to read grass vectors and rasters. But
> r.out.gdal depends on building grass --with-gdal
as I know it's opposite - r.out.gdal depends on building GDAL --with-grass
like in my case when I didn't do it and I get:
r.out.gdal
ERROR: GDAL installation does not support GRASS.
    Recompile GDAL libraries to use r.out.gdal
>. I've also found that,
> at least for r.in.gdal, it crashes in grass 5.0 and works fine in grass
> 5.7.
and can somebody say if both r.in.gdal and r.out.gdal work fine in Grass 5.3
CVS after having compiled GDAL --with-grass?
Maciek
