[Gdal-dev] Re: Gdal-dev Digest, Vol 4, Issue 9
Steve Halasz debian at adkgis.org
Fri Sep 10 12:26:31 EDT 2004
Stephan,
Where did you get the patch? I suspect it is out of date. Try replacing
grassdataset.cpp with:
http://mpa.itc.it/radim/qgis/gdal/grassdataset.cpp3
And be sure you are using this patch for configure.in:
http://mpa.itc.it/radim/qgis/gdal/configure.in.patch2
Steve
On Fri, 2004-09-10 at 12:13, Steve Halasz wrote:
> On Fri, 2004-09-10 at 11:38, Stephan Holl wrote:
> > Hello Steve,
> > On Thu,  9 Sep 2004 14:58:38 -0400 (EDT)
> > gdal-dev-request at xserve.flids.com wrote:
> > > Try adding /home/steph/cvs/grass57_cvs/dist.i686-pc-linux-gnu/lib to
> > > /etc/ld.so.conf and running ldconfig.
> > Thanks for the suggestion. I already did that, but the same error
> > appears.
> Did you run autoconf after applying the patch?
> Steve
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
