[Gdal-dev] gdalinfo --formats reports envi but doesn't read an envi
Carlos A. Rueda carueda at ucdavis.edu
Sat Sep 11 20:25:25 EDT 2004
Hello,
I'm having this strange behaviour:
    machine-1> gdalinfo --formats
    ENVI (rw): ENVI .hdr Labelled
but:
    machine-1> gdalinfo envi_image1.bsq
    ERROR 4: `envi_image1.bsq' not recognised as a supported file format.
    GDALOpen failed - 4
Of course, envi_image1.bsq *is* an envi standard image.
In fact, if I run the gdalinfo command from a different machine
(let's call it machine-2), it just works fine. The interesting thing
is that the binary I'm running is the same on both machines (through
networked directories).  Some details about the machines:
machine-1:  (debian) linux 2.4.18-bf2.4,
machine-2:  (debian) linux 2.4.18,
I compiled GDAL from cvs in machine-2.  LD_LIBRARY_PATH points to
the same location where the different dependencies (libraries) were
installed before running gdalinfo.
Even more interesting is that on machine-1 (where the above example
fails) the command succeeds for other essentially similar envi images ...
Any ideas?
thanks.
carlos
