[Gdal-dev] gdalwarp/gcps and ERROR 1: Failed to compute polynomial equations of desired order
Tue Sep 14 15:30:57 EDT 2004
Ethan Alpert wrote:
> Greetings,
> This is my first post. I tried searching around for examples but didn't
> find much and mailman's search capability is non-existant.
> So what's the secret for using more than 4 gcps with gdalwarp?
> I have 3 pieces of imagery I'm mosaicing. I know the corners of each
> image. I created a single non-projected tif of the three separate
> images. I computed where (in pixel space) the top two corners of the
> first two images are in the resulting tif and where the bottom two
> corners of the last image are. This resulted in 6 GCP points. So I ran
> the following:
> gdal_translate  -gcp 0 0 56.7468972222222 29.4295138888889 -gcp 859 0
> 56.9820861111111 29.4210638888889 -gcp 0 1363 56.7391 29.1199027777778
> -gcp 859 1363 56.9705611111111 29.1071416666667 -gcp 859 2171
> 56.9677027777778 28.9774388888889 -gcp -gcp 0 2171  56.7381583333333
> 28.9917333333333 mosaic.tif mosaic_raw.tif
Ethan,
I think the problem is the "-gcp -gcp 0 2171..." part.  The first -gcp
is being accepted, and then atoi() is called on the second so is effectively
being treated as "-gcp 0 0 2171 56.7381583333333 28.9917333333333".  That
is, the gcp is all screwed up.
You might want to use gdalinfo on your output files with GCPs to verify they
look sensible.
I think you will find things work somewhat better once the GCPs are correct.
However, there some issues with the GDAL polynomial warping.
1) gdalwarp creates a forwards and a backwards transformation from the GCPs
    but creates them independently by reversing the GCPs.  They aren't true
    inverses.  The forward transform is used to compute output bounds, but the
    reverse transform is what is actually used in the warping.  With highly
    non-linear GCP sets this can have damaging effects.
2) I don't think the higher order polynomial calculations are actually working
    right.  I would discourage using anything over second order.
Best regards,
