[Gdal-dev] How to add a NODATA flag to GTiff data?
Thu Sep 16 13:53:04 EDT 2004
Thom DeCarlo wrote:
> Hello,
> I've got several IFSAR DEM files in geotiff format. Each has a border of
> NODATA values (-9999.0) around the real data. My OpenSceneGraph application
> (osgdem, which uses gdal to read the input data) should understand that the
> default NODATA value is -9999, but it uses that value instead of ignoring
> it.
> I remember that when I translated ArcGrid data, which had NODATA values
> defined in the header, to geotiff the output had a NODATA field in the
> header. My question now is how do I add the NODATA field to the geotiff file
> when translating from geotiff or Erdas Imagine format?
Thom,
Currently gdal_translate has no mechanism to set a nodata value during
translation.  However, you can convert a file to VRT format, and hand
edit in a nodata value then translate that back to TIFF.
eg.
   gdal_translate -of VRT in.tif work.vrt
   edit work.vrt (add <NoDataValue>-9999</NoDataValue> tag on VRTRasterBand).
   gdal_translate work.vrt out.tif
It would be nice to have a smoother way of doing this of course.
Best regards,
