[Gdal-dev] memory leaks (?) from using importFromESRI
Fri Sep 17 01:48:12 EDT 2004
Ben Discoe wrote:
> When i call:  OGRSpatialReference::importFromESRI()
> it calls:  InitDatumMappingTable()
> which allocates a bunch of stuff, including a big array like this:
>     papszDatumMapping = (char
> **)CPLCalloc(sizeof(char*),nMaxDatumMappings*3);
> This memory never seems to get freed.  I looked for, but didn't find, a
> function like FreeDatumMappingTable().
> Is there any way to avoid this leak?
Ben,
There does not seem to be a way around this.  If you file a bug on it, I will
try to rectify this by the 1.2.3 release.
Best regards,
