[Gdal-dev] HDF config question...
    Jeroen Ticheler
    Jeroen.Ticheler at fao.org
    Fri Sep 17 07:45:25 EDT 2004
Hi Nicholas!
I read your (old) thread on problems compiling HDF into GDAL. I found a
solution (working on MAC OS X) after facing exactly the same error
message:
on line 226 I added hdf as a format, don't know why it was not there.
It now reads as
GDAL_FORMATS = 	gxf gtiff hfa hdf4 aigrid aaigrid ceos ceos2 iso8211
xpm \
		sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b \
		nitf bmp pcidsk \
		@OPT_GDAL_FORMATS@
It than found the libraries.
Before doing this I also ran:
sudo ranlib /usr/local/lib/libmfhdf.a
but I'm not sure if that was needed really.
Hope it still helps, if not maybe it does for others.
Ciao,
Jeroen
