[Gdal-dev] OGRPolygon::get_Area() and OGRLineString::get_Length() question
Fri Sep 17 09:38:31 EDT 2004
ksa wrote:
> Hi, Frank!
> Method OGRLineString::get_Length() calculates length of the LineString on a
> plane. Why on a plane? Whether it is planned to calculate length LineString
> on elipsoid?
Sergey,
Well, the obvious reason why it is calculated on a plane is that is much easier
and it is the answer that *I* would normally want if I needed the length of
a line string.
I have no plans to compute length on the ellipsoid.
I looked at GEOS quickly, and it seems to just return the planar length for
linestrings.
> Other question: whether it is planned to realize in the near future method
> OGRPolygon:: getArea ()?
Hmm, good point.  Computing planar area of a polygon is not rocket science
and I have done it in lots of other places.  I will look at implementing it
today.
Best regards,
