[Gdal-dev] TIFF Compressions Disabled (Unix)
Wed Sep 22 09:26:02 EDT 2004
Julien Demaria wrote:
> Hi,
> Maybe I'm wrong but it seems that at least PACKBITS and LZW TIFF
> compressions are disabled under Unix in the current GDAL CVS (and in
> 1.2.2 version) :
> in frmts/gtiff/libtiff/GNUmakefile only pass the -DZIP_SUPPORT
> -DPIXARLOG_SUPPORT -DJPEG_SUPPORT
> and the makefile.vc pass -DCCITT_SUPPORT -DPACKBITS_SUPPORT -DLZW_SUPPORT \
>         -DTHUNDER_SUPPORT -DNEXT_SUPPORT -DLOGLUV_SUPPORT \
>         -DZIP_SUPPORT -DPIXARLOG_SUPPORT -DJPEG_SUPPORT
Julien,
I am afraid you are quite correct.  I had noticed this and talked to Andrey
about it briefly, but then I forgot to ensure it was corrected before the
release.
In the meantime I believe you can just add the extra defines in the
gdal/frmts/gtiff/libtiff/GNUmakefile.
Change:
ALL_C_FLAGS	=	$(CFLAGS) -DZIP_SUPPORT -DPIXARLOG_SUPPORT -I../../zlib
to:
ALL_C_FLAGS	=	$(CFLAGS) -I../../zlib \
I have created a bug report to track this problem:
   http://208.24.120.44/show_bug.cgi?id=616
I will try to issue a GDAL 1.2.3 within a few weeks since this is a fairly
noteworthy flaw in 1.2.2.
Best regards,
