[Gdal-dev] grass in 1.2.2 compilation problem
Steve Halasz debian at adkgis.org
Wed Sep 22 14:55:36 EDT 2004
I'm attempting to compile 1.2.2 --with-grass against grass 5.7.0. I end
up with:
make[2]: Entering directory
`/home/steve/projects/qgis/debian/gdal/gdal-1.2.2/ogr'
/bin/sh ../libtool --mode=compile g++ -Wall  -O2
-DCPL_MULTIPROC_PTHREAD   -Iogrsf_frmts -I. -I../port -I../gcore
-I../ogr -I../alg   -I../port  -c -o ogrinfo.o ogrinfo.cpp
 g++ -Wall -O2 -DCPL_MULTIPROC_PTHREAD -Iogrsf_frmts -I. -I../port
-I../gcore -I../ogr -I../alg -I../port -c ogrinfo.cpp  -fPIC -DPIC -o
.libs/ogrinfo.o
-I../gcore -I../ogr -I../alg -I../port -c ogrinfo.cpp -o ogrinfo.o
>/dev/null 2>&1
/bin/sh ../libtool --mode=link  g++  ogrinfo.o ../libgdal.la -o ogrinfo
g++ ogrinfo.o -o .libs/ogrinfo  ../.libs/libgdal.so /usr/lib/libodbc.so
/usr/lib/libltdl.so -L/usr/lib -lxerces-c /usr/lib/libjasper.so -lmfhdf
-ldf -lgif /usr/lib/libjpeg.so -ltiff -lpng -lnetcdf -lcfitsio
-L/usr/lib/grass57/lib -lgrass_I -lgrass_vask -lgrass_gmath -lgrass_gis
-lgrass_datetime -lz -lpthread -ldl -lpq
../.libs/libgdal.so: undefined reference to `G_gisinit_2'
../.libs/libgdal.so: undefined reference to `G_check_cell'
../.libs/libgdal.so: undefined reference to `I_check_group'
../.libs/libgdal.so: undefined reference to `G_get_cell_as_proj4'
collect2: ld returned 1 exit status
make[2]: *** [ogrinfo] Error 1
make[2]: Leaving directory
make[1]: *** [ogr-apps] Error 2
make[1]: Leaving directory
`/home/steve/projects/qgis/debian/gdal/gdal-1.2.2'
make: *** [build-stamp] Error 2
It appears that it is trying to compile the libgrass version. Renaming
frmts/grass/grass57dataset.cpp to grassdataset.cpp didn't work either. I
looked for where the logic to decide which to use was and couldn't find
it.
Thanks,
Steve
