[Gdal-dev] Create method
Fri Sep 24 10:57:56 EDT 2004
Julien Demaria wrote:
> good solution... have you got a simple example code which do that, if
> possible ?
Julien,
I'm afraid I do not.  The key is to create a VRT data and VRTSourcedRasterBand
and then add a VRTFuncSource to it.  The function in the VRTFuncSource will be
called as imagery is needed.
Best regards,
