[Gdal-dev] Creating overviews in different folder
    Daniel B äck
    daniel112b at home.se
    Tue Sep 28 10:43:24 EDT 2004
Yes i would like to use the overviews with the original file, supplying a location or name of the overview file in the call to GDALOpen or similar.
The solution with the .vrt dataset might work out nicely for me, creating it with CreateCopy in the new location. Any immediate draw backs to this solution?
Thanks,
Daniel
On Tue, 28 Sep 2004 09:00:38 -0400, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Daniel Bäck wrote:
> > Hi,
> > I would like to be able to create external overviews in a different folder from
>  > the original file. The data might be on a shared nework drive where i don't have
>  > write access and it could be very handy to be able to be able to keep the data
>  > from others clean from my files.
> > It would be very easy to use if you could supply the overview filename to
>  > BuildOverviews and GDALOpen but that would break the binary compatibility.
> > GDALDefaultOverviews allready supports overviews with a different location
>  > trough the pszBasename parameter of Initialize and BuildOverviews.
> > Any thoughts on how to change/add the interface to support this?
> Daniel,
> Do you want to be able to use the overviews with the original file?  If
> so, it isn't clear how GDAL is going to put the overviews and the original
> file back together again.
> On unix, a solution to the problem would be to create a soft link on a
> filesystem you do have write permissions to, pointing to the original file.
> Then gdaladdo would be able to create an external overview file in the
> same directory as the soft link.
> On Windows, this isn't really practical.  One relatively recent change made
> in GDAL was to support building overviews for virtual files.  So on windows
> you could do something like:
>   gdal_translate -of VRT x:\target.tif c:\target.vrt
>   gdaladdo c:\target.vrt 2 4 8 16
> This should result in creating a small .vrt file that refers back to the
> original .tif file.  And the overviews should be built as c:\target.vrt.ovr
> and used automatically when you work with target.vrt.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
