[Gdal-dev] GDAL 1.2.3 Formally Released
Wed Sep 29 09:41:03 EDT 2004
Folks,
Ben reminded me I didn't formally announce the 1.2.3 release.  After a couple
small patches from the release candidate I have published a formal 1.2.3
release as of Sunday or so.  Note that 1.2.3 is essentially just a bug fix
release.
GDAL 1.2.3 - Overview of Changes
GeoTIFF Driver:
     - Fixed many missing compression codecs when built with the internal
       libtiff.
     - Modified driver metadata to only list available compression types.
DODS Driver:
     - Added support for OPeNDAP version after 3.4.x (use of opendap-config).
GRASS Driver:
     - Fixed support for building with grass57.
MrSID Driver:
     - Fixed support for MrSID Encoding SDK.
NITF Driver:
     - Fixed serious bug with non-square output files.
OGR 1.2.3 - Overview of Changes
OGRSpatialReference:
     - Corrected memory leaks - OSRCleanup() cleans up temporary tables.
     - Fixed build problem with ogrct.cpp on Solaris.
TIGER Driver:
     - Improved generality of support for GDT files.
OGRGeometry:
     - Added getArea() method for rings, polygons and multipolygons.
The 1.2.3 source may be downloaded from:
   http://gdal.org/dl/gdal-1.2.3.tar.gz
   http://gdal.org/dl/gdal123.zip
Best regards,
